Wiring up a Second horn
Rustyspokes
I would like to wire up a second horn in my 34, an Ahooga, using a Start button as a switch; (horn button ,) and a fuse inline with the horn , can someone tell me how to do this, or draw a circuit diagram, thanks in advance ..:)
You need a relay to carry the current. A little more information is needed, do you want it to look somewhat original or could you care less?
I'd have to agree that a relay would work best, but certainly many a Model A's horns work fine without a relay. Model A's horn has power to it all the time, the horn button provides the ground. Is your car 12 volts or 6? Positive or negative ground?
This would be for a horn that required power to operate. If it requires a ground to activate, I would use a normal horn relay.
Thanks ....JSeery ....I think I will use the 3rd Diagram, a 6 volt system , with the Horn Relay, thanks Guys really appreciate your info, I have an extra Starter PB already mounted I am going to use, thanks .. R:)
