JtownJoe
Help with tracing electrical short. I have a slow drain on my battery with all systems off. I have installed battery cut off but I would like to find & eliminated the problem. No lights or ignition, coil, points & etc are staying on (small needle movement is showing on amp. gauge) short occurs as soon as positive cable is connected to the starter terminal. I traced it up to the firewall terminal box and eliminated any shorts in the dash components so I am thinking it is somewhere in the bowels of the wiring harness, any suggestions to help find it? I have a voltage meter that beeps when hooked up between the negative battery cable & the starter terminal but not sure how to isolate from there.
