cooke
I have the Signal Stat 900 installed but I am having a couple of problems.
The indicator light on the Signal Stat do not light up, I think I need a better ground to the steering column to fix this?
When I turn on either the left or right signal the front cowl lights, (standard single filament bulb), work fine but the rear LEDs both right and left blink at the same time whether you are signaling left or right both blink.
My brake lights no longer work, other than that everything works great
I have checked that all wires are connected according to the wiring diagram.
I am sure that both rear lights blink simultaneously because the parking lights run from the driver’s side to the passenger’s side, if I cut that wire I think my blinkers will work but the parking light on the right will not. Maybe I have to go to twin filament bulbs??
