richard rink
I recently bought a '53 ford car. While the engine is out for a rebuild, I have been checking some of the wiring-it is original, cloth-covered. Some of it need replacement. I have the wire diagram for the '53 and have been tracing the circuits for the "y" wire which has to do with the ignition and charging systems and probably much more.
One y wire extends from the battery terminal on the voltage regulator to the circuit breaker. That connects with a y wire that goes to the ignition switch.
The other y wire comes from the starter solenoid (battery side) and passes to the middle terminal of the horn relay. From there, I am unable to determine its path...can't see it on the wire diagram.
Any suggestions? Thanks in advance. Richard
