I'm not very knowledgeable regarding the differences between Ford and Mercury. I should think the wiring would be very similar. Maybe use a diagram for a full size ford or even a Thunderbird. This is a copy of a diagram from one of my old Thunderbird Parts Digest books. The 4 way selectomatic is different. This diagram is for the regular four way power seat for Thunderbirds 1955 through 1957. I assume the full size fords are the same so it might also carry into Mercury. If the wire color codes on your car are the same I would think that this diagram would be correct for your application.
Or..... If your car has the selectomatic type switch I can supply that wiring diagram from my Thunderbird book.
