mngreen
Hello:
Does anyone have a wiring diagram for a GM Delco-remy alternator setup with a voltage regulator separately mounted on the firewall? I have a 12V negative ground setup.
There are two wires coming from the three connector pins (one unused) on the alternator and another wire connected to the + pole of the alternator.
I am also looking to install an amp meter where appropriate in the circuit.
Thanks,
Mike Green
Thanks,
Mike Green
