Jim in S.C.
I just today (sat) recieved two electrical parts from Snyder's. Just in time for a weekend project. Item #1 a voltage reducer for 12 to 6 volt for the sparton horn. It has 2 wires It also came with a wireing diagram. I think I could have hooked it up without a diagram ( pretty ) simple. Then I opened the box with the flasher in it. Snyder's part #A-13311-12x I also ordered a base for the flasher. It has 3 wires coming out of the base and 1 short wire out of the top of the flasher. There was no wireing diagram with the flasher. I assume 1 wire goes to the 12 v pos. feed 1 wire to the turn signal selector and 1 wire to ground. I have no idea where the little wire out the top of the flasher goes. but which to where. I would like to install it tommorow. I SURE DON"t want to cook it! Can any of you barners tell me or show me how to wire this flasher up. The flasher has a beeper in it and it is suppose to work LED lights.
Thanks in advance
Thanks in advance
