Old Redneck
I know I need to seal the Wire Tires for leaks. Have any of you ever done this? That my next project to do. I did search on Google how to do this.
I got talk in to buying them so I got to make the best of it. Tubes are no good in Radial tires. On open highways they get very hot and blow up. I had that to happen to me.
"I have NEVER trusted aftermarket wires that have been slugged full with silicone or other types of sealant over the inside face of the rim."
Wire wheels require a little extra care when mounting tires. First, regardless of the type of tire you purchase, wire wheels require the use of an inner tube. For clarification, "tubeless tires" mean the tire bead is designed to provide an airtight seal against the rim. It does not mean you cannot use an inner tube. Of course tires produced prior to the tubeless technology will always require an inner tube as will any wire wheel. This may seem obvious, but whenever you are mounting new tires on wire wheels remember to use new inner tubes. Inner tubes will degrade over time just like tires, and while the tube may look good, you should still use new tubes.
"Tubeless" tires weren't designed to be used with tubes.
Tubeless tires gradually lose air when punctured. Tubes pop like a balloon when punctured, losing all the air at once (not good). It was common (in the old days) to put a tube inside a tubeless tire that could not be plugged/patched, rather than replace the tire. I don't recommend it, but it's the only way you will keep air inside your tires/w spoke wheels.
Tubeless tires are pretty straight forward. In most cases you can mount them to the wheel, and air them up, and they will remain inflated, unless there is damage to the tire or wheel. With that said, buying a tubeless tire doesn't mean that you CAN'T use a tube. It simply means that the bead is designed to seal against the rim without the use of a tube. As mentioned, wire wheels require the use of tubes. When it comes time to buy new tires for your vintage car, truck or motorcycle, always remember tubes, rim strips and/or flaps if applicable.
