Wire Wheel support ring for use with later Brakes
Andy
Kerrville
Tx
Price
$40
Offered is a set of four wire wheel support rings. The rings are used with 32-35 Ford wire wheels and also with the Kelsey wire wheels. The wire wheels have a stepped mounting surface. If the wheels are bolted down to later 40-48 hydraulic brake drums, the flat surface does not support the wheel as the wheel only contacts the drum on the outside of the studs. The rings add thickness where needed so the wheels will pull down tight and not be warped when tightened. The rings fit snugly in the ring depression designed into the wheels. They can't move around and are clamped by the wheel. They are usually epoxied to the wheel. They can also be tack welded. The rings are lazer cut so have no warpage or slag. The are shipped priority mail for $5 so total is $45 shipped.
