Wire Harness Routing
Fixncats
I just pulled the 59 AB from my 1936 Ford for a rebuild and noticed the headlight harness was routed over the top of the bottom radiator hoses. I'm certain that's not correct. Should it be secured to the cross member or go in front of the radiator? Thanks
Hi Everyone. Fixncats, Welcome to the FordBarn Forums!
Yes, the '36 headlight harness runs below the hoses, on the side of the rad that the driver looks at, clipped to the crossmember, I think with two clips.
Great diagrams here, but not showing the clips. Maybe that's in the '35-36 Book that the EFV-8 Club publishes, written by member Don Rogers. I don't have it close enough to look right now. http://www.vanpeltsales.com/FH_web/flathead_drawings_electrical.htm
Hi Everyone, I'm replacing the electrical harnesses on my 1936 Ford with my engine out. Question, one side of the new firewall grommet has a large hole and the other a small, which way does the grommet face? Thank you
Fixn; the large side of the firewall grommet faces the engine.
On my 35, the headlite wiring crosses over from one side to the other OVER the bottom radiator outlets, there are a couple of little clips soldered at the bottom of the core/top of bottom tank, that hold said wiring loom in place. As 35 and 36 share the same wiring, I'd imagine 36 is routed the same.
agree with brian, there was little tabs soldered onto the bottom radiator tank to hold the wiring in place.
Here are some photos that should answer both your questions. One photo shows the headlight/horn wiring being routed across the bottom of the radiator on top of the rad hoses and held in place by a clip ( 1 clip not shown)
The other image shows the main firewall grommet with the smaller opening facing the engine compartment.
Hope that this helps...Don Rogers
when i put the new engine in my 36 pickup, i wired up the spark plug wires , and the engine harness on the engine stand. the generator wire and the coil wire need to go through the conduit i cant imagine doing this in the car
