Wiper question
AZ Chris
Trying to find replacement blades and arms for a 40 Standard Coupe and cant seem to find a good match to what came off the car and look to be the original hook type.
The blades look both to be identical with all the same markings and are 7 1/4" but all I can seem to find are 8 1/4" although I see that Snyder's lists a 7 1/4" for 28-29 Model A.
The arms appear to be different with the LH having patent markings where the RH does not. Both have an S stamped on them. Also the rivet on the RH is larger. Where Drake shows 5 1/4" from center of the pivot to the "dimple" these are 5 3/4.
Overall the length from the center of the pivot hole to end of the blade is 10 1/4".
Anyone run into this before?
Thanks
