W waldo Member Apr 3, 2016 #1 Having trouble removing the wiper control cable and knob from the dash. Any help appreciated. Thanks
bobss396 Well-known member Apr 4, 2016 #2 There is a dash bezel removal tool sold by most Ford parts houses, I've seen needle nose pliers used but the tool works much better and less chance of scratching up the dash.
C cb Senior Member Apr 5, 2016 #3 The knob has a small set screw that holds it to the shaft, once you get the knob off the bezel unscrews and pull it out through the back.
