Now you know why they have the adjustable aftermarket arms on there. Those only cost $39.99 while the correct repro CV, convertible arms cost $97.99.
If you get the 6-1/4" long repro's with bayonet arm (# B5A17526-DPR) and pay the big bucks, they'll fit on your pivot fittings but then you may need to pay more to get wiper blade assemblies to fit the bayonet type arms.
I don't like those adjustable aftermarket types, because if your vacuum wiper motor is not fully returned to zero, the pivots are not all the way down and you will suck a small amount of vacuum all the time.
To install the correct wiper arms, remove old wiper arms first, then start engine, run the wipers thru one cycle and shut off with engine running and no wiper arms, so that the pivots will return to zero vacuum position. Then install wiper blades on wiper arms and press wiper arms onto the pivots. If you get an arm one notch off, you can remove and re-install again till you get both to match.
