Gary,
I like to have some type of music playing if I am working too! I do a lot by myself and it somehow keeps me motivated. I really like the battery tray and support! Well designed and built. The truck looks great with the engine in place. My guess is you will like the low end torque of the 6 cyl.
You're making great progress! Must not be far from firing it up??
Thanks for the update.
Now I need to get out and work on something!
Regards,
Chris
I cranked it over this afternoon. I have solenoid on the firewall, made up some really good battery cables from junk I found around here, made an adjustable linkage from pedal assembly to carb. Scrounged an original choke cable that goes into the squared off hole in dash with a clip and terminates with a spring loaded end for the ball. After all this time it operates like a new cable without lubing it. I also installed a 1310 series U Joint at the rear of the two piece driveshaft. The tonner uses 3 of them and are a very common size. My Napa had 4 in stock yesterday. The 2 piece driveshaft assembly is sill sitting on the tailgate, so tomorrow I will crawl down under and bolt it up. Firing it up won't be a big thrill as I had it running on the stand a bunch of times. I have front brakes all re-done and that's enough for granny gear, just in case I have to go for as drive tomorrow. Driving it will be fun.... if all these used parts are as good as I thought they'd be!
I'm sure you know about driveshaft phasing but just in case:
Being mechanically challenged I have no idea about driveshaft phasing. Can someone explain the reasoning why this must be followed?
Tom
Balance issue as I understand it. All I know is that if its not phased properly there will be a noticeable vibration when driving.
Well, not quite! Phasing really has nothing to do with balancing, as such. To understand the theory, one must first realize that any time a u-joint is at SOME angle (NOT in straight alignment), the drive shaft actually speeds-up and slows down four times per rotation. The greater the angle that the u-joint is deflected, the more pronounced the effect.
If both joints on a shaft are in phase, the slowing down and speeding-up should have an identical effect from EACH u-joint, making the function completely similar and complementary for BOTH joints. If the two u-joints are out of phase with each other, the two ends of the shaft will be trying to speed-up and slow down at different times in the cycle. That can only cause twisting and vibrating and all sorts of contortions going-on with the drive shaft in that situation.
In other words, EACH u-joint MUST speed-up and slow down at exactly the same time and rate. DD
Driveshaft phasing demonstrated : https://www.youtube.com/watch?v=Idk3BVDVHq4
Yesterday I made some temporary support rods for the radiator from some conduit I found up in the rafters. While running the six on my stand for a couple buddies I blipped the throttle and sucked the radiator back into the fan. Yikes! The hoses seemed enough to star it (untilt they softened with the heat). Just cosmetic, no leaks, but I know myself well enough to know I will want to do a few shakedown runs before I install the front clip. This time I have brakes so shouldn't be ruining THIS new radiator crashing through my wife's henhouse yard. I have grown up a lot since that incident.
“I have grown up a lot since that incident.”
CONDUIT!!…..you didn’t just cut the handles off her broom and her mop?!?!?…..Well, you certainly have grown up!!……LOL……Mark
