Winter Storage
Only have about a few weeks a year where the ground is in no condition to drive the A. But we also don't have any plows or salt trucks so when we get ice or snow, we cant drive our modern cars either.
The answer at my house is the insulated garage and mouse proofing!
30ccpickup .......................
I just read the tips of winter storage. I was thinking that it had been proven to be an "Old Wive's Tale", to not store your battery on a concrete floor - that it would drain your battery.
What is the scientific basis for this theory ?
Any ideas ?
MIKE :)
Actually setting the battery on the floor will not discharge the battery any faster than setting it on wood, or a shelf, etc. However, a quick search on the internet found that this is information that has been passed down through the ages, and at one time was actually true.
Historical Basis You see, the myth that concrete drains batteries does have some historical basis. Many, many years ago, wooden battery cases encased a glass jar with the battery inside. Any moisture on the floor could cause the wood to swell and possibly fracture the glass, causing it to leak. Later came the introduction of the hard rubber cases, which were somewhat porous and had a high-carbon content. An electrical current could be conducted through this container if the moist concrete floor permitted the current to find an electrical ground. The wise advice of the old days to "keep batteries off concrete" has been passed down to us today, but it no longer applies because of the advanced technology of today’s batteries.
Today’s Technology For more than a decade, automotive and commercial battery containers have been made of polypropylene, which is a highly insulative material. In fact, the Interstate Batteries poly material is at least five times more insulative than the old hard rubber. Also, tremendous technological improvements have been made in the seals around the posts and the vent systems, which have virtually eliminated electrolyte seepage and migration.
Battery Discharging The fact is, all batteries self- discharge whether they’re sitting on the shelf or on concrete. This is why we regularly rotate your inventory. As the temperature increases, a battery’s self-discharge level also increases. Some lead acid batteries discharge 4% - 8% per month at a temperature of 80°F. The level of self-discharge is also contingent upon the type of lead plate alloy plus the age and cleanliness of the battery.
If the battery has a surface layer of acid or grime, which is electrically conductive, it self-discharges more rapidly. This surface layer may actually allow you to measure the DC voltage across the battery’s poly case (using a 10 meg-ohm digital voltmeter). For that reason, we recommend that you always keep batteries clean, whether they’re in storage or in a vehicle.
Grandfather Clause
You may now be thinking that you know more than your grandfather, who tells you that batteries stored on concrete will be damaged. Next time your grandfather says that, I recommend that you just say "Okay" and continue about your business. I’m a grand-father now, and I know that we like to have our way and we like to be right. If my grandson, for instance, tries to tell me that concrete won’t damage a battery, you know what I’ll say? I’ll say if you drop a battery on concrete, it will be damaged.
At one time it was true. The insulating materials of the battery were poor. The moisture of the concrete would cause them to slowly discharge. Modern batteries are better insulated and can be stored on the floor.
