Winter build project T body
32 chevy vett
I cut down sum ash and had lumber made. About ten years ago.I had staked up stairs. So thought it was time to build a six post delivery express wagon.
I started with making the body mounts.
I primed and painted the frame work. Worked on the floor boards and side boards.
keep the pictures coming i built a 1929 and 1930 huckster wagon from hard maple that i cut down had one man saw mill saw up let air dry all summer then staked in my heated shop all winter had a lot of fun next two years more fun working with wood than metal have fun keep us up to date
Very cool project, one of these days i'd like to do one myself. are you working from prints or pictures?
Thanks
Scott
Thanks guys I said at the beginning I had the lumber made up. I just had a C.M.S. attack. I milled them up my self with a Alaskan chainsaw mill.
Visionary I bought an original that was all a part.The firewall and roof were missing.
I made them up. And traced all the parts on a roll of paper. After ten years in the shop. I saved all I could. And went by photos for the rest.
I bent and welded up all the flair irons. Cut,bent and drilled most of the steel for the six post. Drilled bent and finished the tail gate.
thanks for posting this build. somthing I have been running thru my head for a while now, however never being able to leave any thing stock or original, I was planning on using a 29 Reo Flying Cloud. post lots of pics. as I would like to follow this build very close thanks
Hi TnA There is no reason you can't do that. As long as you got a 29 Reo frame.
I will try to give more detail photos. If you come to a spot. You need help. Let me know.
well , as a matter of fact, I purchased a 28 AA frame as it has a worked over front end, as for thr rear end I can use parrelel springs, and I have a 54 dodge flat 6 to install under the hood . ohoh tradional forum builds only, my bad:D:D
Rear floor showing battery box and opening. Seat showing gas and tool box opening.
Looking in tool box. Added flair irons and side rails. Added trim 1 1/4"x 1/4"
Very nice work, Thank you for posting. I'm planning to start my project, a 15 closed cab pick up. The timing is perfect.
JJ
A few more photos. Fire wall,floor boards and side posts.
For some reason i can't send six photos. So heres rest.
I built the one in my avatar about 25 years ago, no plans used. Just finished a woodie body for a 29 model a last fall
Hi tombia Is yours a six post. It's hard to see it good in the avatar.
I had this original to copy.
100 9419
No , Its only 2 posts, The post is right where my left shoulder is, Sometimes not to comfortible and I used touring fenders, wished I had used hack fenders so it would be wider, other than that its been a ball and lots of miles. Wish I could post better pic's.
