Winfield Carb- Identifying Parts?
svm99
I've acquired some carb parts which I've ID'd as Winfield. Are there any published lists which are available so I can ID these parts for which size carb they fit? Some are stamped BB, C, CC so I assume these would be for that size carb.
Thanks for the help, I am usually on the A & V8 forums so am new to the T forum though I was "raised" on T's.
Paul J.
Hello Gilroy.....
Yes that is the size and on the float bowl there are more numbers U for Updraft and
D for down draft. The BB is a nice size for a model A. The C for a more warmed over
motor and the CC pretty much a racing size.
How complete are they? some pics would help.
If your going to run one I can send you info. I'm in Marin Co.
Dodge
I'll post some pics in a day or so as I know that will help. I only have the parts, no carbs which is why I need some assistance in ID'ing these parts.
Thanks, Paul
Winfield did a good job numbering and lettering most pieces so should be able to id.
The carb bodies were shipped empty to dealers and jets shipped separatley so most
carbs were custom built.
