Windwing
joltesvig
There a two types of windwing mounting brackets to choose from.
The first requires drilling through the paint to screw on the brackets.
The other has brackets which fit into the channel so I won't have to drill through the finish paint. Do these interfere with rolling the side glass up and down?
Which ones are better and what are the pros & cons?
Oh, sorry, I should have said that I have a 31 Coupe. It has pretty good paint so I really do not want to drill holes if it isn't really important to do so.
The type that sets in the window channels are an excellent reproduction of an original 'Fulton' accessory wind-wing, last made by A & L products. All of their products are Excellent and first rate. The other type that you screw into your doors are a much more common reproduction done by at least a couple of manufactures. All of my many original cars over the years have had the original wind wing brackets that screwed into the door. They all worked great and looked great. So when my latest acquisition came without windwings, I started researching to see what was available in the reproduction market. As I had a really beautiful paint job on the car, I too was apprehensive and nervous about drilling holes into the car's doors. (somehow this did not seem an issue to me 50 years ago when the cars came with the original windwings already installed). But I 'bit the bullet', made careful markings, and drilled undersized holes in the appropiate spots, and screwed the repro brackets onto / into the car's doors. Once the mental pain subsides, and the finished product smiles at you, you will be glad that you added them to your car. One note, the original brackets had a leading edge that had a rubber 'gasket' that closed the gap between the door and the leading edge of the glass. The repros do not have this important and practical 'finishing touch'. You can add this yourself, by getting an appropiate-fitting rubber (I used an insullation strip) and fit it (lite glass glue helps) to the leading edge of the windwing's glass. The other thing that I found to be a temporary 'issue', was that the screws protruded out into the space between the door and the car body. Besides looking 'ugly' these are a hazard. Just cut these protrusions off, leaving a little 'meat' to add 'depth' to the holding action of the screw. You might want to ad 'Lock-Tite' or someother insurance policy to the screws.
- Doug Vieyra, Eureka, Calif
On a similar note, are there windwings and brackets made for a 28 closed cab pickup?
If so, does anyone have pics of fitment?
Not sure about the pickup but would like to know because my son has a 30 pickup and may be interested in adding windwings if they are available for a pickup.
For my 31 Couple, taking into account all the feedback, I think I will go with the windwing brackets that don't require drilling though the paint. Thanks all for the comments.
John
Her is a picture of my original clamp in windwing upper bracket. It does not interfere with the window. They are great because you can remove them when necessary, especially for car games
