Windshield
oneofone
I have what I think is a windshield from a 26 or 27 roadster but it seems to be missing the pieces that hold the top of the bottom glass and the bottom of the top glass. I also have four 90* bolts that are only threaded on one end and four levers that are round where they should attach to whatever. So if someone had a pic it would really help since I got this as a basket case. Thanks, j
They should go in the gap between the upper and lower frames. I have no idea what the bent bolts are for but they may have been part of a home brewed set up.
Sorry, but that looks like a possible GM windshield, not a ford. They look similar but a ford lower windshield does not bow up all the way across. Curves up slightly on the ends and then flattens out.
