Bruce of MN
I can’t find windshield glass on the Brattons, Snyder’s, or Bert’s websites. Am I searching wrong or is the glass not available?
Mine were made at a local glass dealer. Dimensions are in the Model A Service manual. You want laminated glass.
Hold a match or a lighter close to the glass.Wiggle it around a little and if it is laminated you will see a reflection plus almost a shadow reflection.You can also set something like a business card edge against the glass and angle it around.You will see a reflection plus the shadow reflection when you hit the correct angles.Plain glass will always give you just one reflection,no matter what you do.There is a row of screws going straight up into the header that holds the hinge.Unhook the swing arms and swing the windshield out as far as possible to get a screwdriver straight onto them.
Usually if you look at the edge of laminated glass, such as from the top of the side windows when rolled down, you can see the two layers with a line in between.I see two reflections when I do the test side windows, too, so thanks for the tip!
