flathead 39
I need to remove and replace the windshield chrome trim and I'm not sure how to remove them (39 deluxe). Any suggestions?
No show car here either, question is how do you remove them?If you are talking about the windshield frame you will need to have it replated, not inexpensive. After getting prices 20 years ago I decided to paint mine since I was not building a show car.
This is a typical 1937 thru '39 Ford windshield frame, although the two tiny clips at the outer sides can be lower, depending on WHICH year. Those tiny clips are pictured. They cover the joint which is the separation location for the upper and lower half of frames. This separation is the feature allowing glass replacement.
Does not require special tools
So, just pry them off with a screw driver?
