Windscreen Frame
DennisR
My windscreen didn`t fit what I`d call properly when I acquired the car. When closed there was a small gap at the top narrowing as it went down to the bottom on the passenger side but on the drivers side at the top the gap is quite a bit bigger again narrowing down to the bottom.
I can see no reason for it, the hinge fits where it should, before I started the refurb I was happy to leave it but as I have had a problem with the frame thought I might as well try and sort it.
Is it common for there to be a gap ? I`ve not had the body off, the gap came with the car, the doors line up and close fine.............
