window run channels?
raj4851
I have a '39 two door sedan. When I was working on some interior stuff I happened to feel that I think is a run channel for the quarter window, the vertical piece of metal that the window runs up and down in. It appeared to be tack welded onto the body. This was a front one. I didn't really see it but felt that it was loose so I pulled it off. Do I contact Bob Drake, Midwest Ford, or Carpenter to get these pieces? I probably need to replace all of them, plus the whiskers. I also need the pieces of metal with felt attached to the body at the window openings. Thanks in advance, Rod
The metal "run" holder must be tack welded back on, then you will need to find the "run". Try Restoration Specialties 814-467-9842.
