window regulators 1930 tudor
Are the window regulators the same front and rear on a 1930 tudor? I'm using the same regulators front and rear and the rear glass does not want to go up straight, Just thinking that they may work better if the arm was longer on the rear.
There are right and lefts,,, fronts and backs are the same... Maybe new window runs and silicone spray on the rubbers will help, along with lubing the regulators
Glass the wrong size and the worn runners could also cause problems.
I agree.
I just got finished fixing some windows with the same problem and found where the glass was too narrow. Installed the correct size glass and now everything works correctly.
Chris W.
