window regulator
oldspert
I bought a new window regulator for my coupe and it does not have any method to roll inside the lower channel. Is there supposed to be a roller or does the end of the regulator just slip in the lower channel of the window frame?
Grease it up good!
One trick: The windows must not have any play in the channels or they will bind. If there is play, space out the channels with some cardboard or other material. Pull the channels out and insert the cardboard perhaps with a spot of glue.
