markwill
Does any one know the trick to installing a new main spring in a Model A window regulator? I swapped a main spring from a broken regulator to a good regulator that was missing the spring. However, I cannot get the preload correct...it's a strong spring and the can't wind it around far enough. There must be a tool or trick to accomplish this.
Thanks.
Thanks.
