1936coupe
my door window glass jammed in up position one riser arm had come out of its track, removed door card and managed to free it but the glass came out (had a crack anyway) the mechanism now goes down at quite a severe angle? which binds the glass,where as the other side winds down horizontal, tried to remove the mechanism to have a look as one arm seems a little bent but cant really tell. but i could not get the mechanism out of the hole in door is there a trick to this? thanks.
