Window glass replacement.
Ron Barber
I am replacing the rear right back window on my 31 Fordor murry model. The window seems to move out of the channel when lowered. I installed the window rubber bedding and coated it with a little oil. Anyone have any advice on how to seat the window into the regulator channel it doesn't hold in the channel when I crank the window down. I was thinking of using a rubber seal.
Thanks for any suggestions!
Ron. :)
The channel should pinch the glass tight enough to hold assuming you have a correct bedding. If using cork it comes in several thicknesses
Also check to see if the glass slides freely in the channels without the regulator
Another thing is to see that the regulator is moving straight up
If not it could be causing the glass to bind which would increase the problem
Oil not good
I cracked both door windows in my 190A because the glass fit into the channels was to tight,and not perfectly straight. I went to a professional glazier and he use a special glue to bed the glass.
