Window door handle crank pins
peewee2you
Elk Grove
CA
Hello, I'm working on a 47 ford, but I think 42-48 window crank handle pins for front door windows. The handle goes on the square shaft that sticks out thru the door panel on the regulator and you put handle on and insert pin to hold the handle on...
(2) needed...
Thanks,
Peter
