Synchro909
Probably I should have said SAE fasteners rather than US fasteners. The reproduction import wind wing clamps that we get have metric fasteners that are tapped too shallow and are poorly fitted to the wind wing clamps. The wind wing clamps have to clamp parallel and tightly to the glass to work properly. Properly fitting fasteners are a must and that is why I now always replace them with proper fitting fasteners. Having SAE taps and dies handy, is why I replace the metric fasteners with SAE fasteners. Nothing much more to it than that. Using proper fitting fasteners makes a big improvement.
Ii agree that the fasteners that come with the WW sets are crappy. That's nothing to do with them being metric, just made on the cheap. The soft metal used in the clamps won't hold a fine thread as well as a coarse one, then there is the fact that they are made sloppy in the first place. The coarser SAE (or Whitworth) thread is much better.
FWIW, the softer the metal, the coarser the thread that should be used. That's why the end of the head studs that go in the soft cast iron block are coarser than the thread in the harder nuts.
