BButturff
If you are big on hand cranking, and not using the starter motor....you can cut a piece of 1/2 copper water line. Take an angle grinder and cut a grove down it lengthwise. Then trim it to the final length you want the position to be (like almost closed ~3/4) Once it's done as you like, pull the rod back, and slip the copper tube over the rod in the cab, and go out and crank it.
You can store it in your door pocket, or your workbench.
Excellent idea! I'm going to do this but use 1/2" PVC pipe to avoid scratches.
