I went through the same issue for about 3 weeks. Good news is that I became an expert at timing. Tempted to put a YOUTUBE out there
Here is what I did which led to solving the problem:
1. Checked the timing.....multiple times and double checked locating the "dimple" with the pin and a mirror
2. Made sure all connections at the terminal block were snug and corrosion free
3. Had 6 volts at the terminals and both sides of the coil.
4. Replaced the coil
5. Replaced the condenser even though it was a week old
6. Of course I adjusted the point gap to .020
7. Gapped the rotor to distributor body to .025 all around
8. Made sure I had fuel to the carburetor
Still no start.
I dialed a friend and he said are you sure you are gapped at .020 and do you have fuel? I tried starting on starting fluid...no start. This convinced me I was not getting spark to the plugs....yes I check the spark out of the coil.
Had a buddy come over and sure enough I was not getting spark to the plugs
What it turned out to be was in fact the points. I did not gap them correctly...they were gapped at roughly .028.
Properly gapped at .020, the plugs fired. Re -assembled and the engine started. Good news is that I completely baselined the ignition system. Now I know what was replaced on such and such a date.
Good luck.....I will bet it is the point gap.
Still no start.
