Fredb_ Well-known member May 29, 2015 #1 Can anyone tell me what year this dash would have been? Thanks Attachments T Dash.jpg 66.8 KB · Views: 21 T Dash_2.jpg 56.1 KB · Views: 18 Last edited: May 29, 2015
Mark W. Senior Member May 29, 2015 #2 Re: What year dash? 1926-7 Model T closed car - not sure which one but I think it is Fordor sedan. Are there 2 holes in the lower flange below where the ignition switch should be? If so, it would be 95% sure on the Fordor
Mark W. Senior Member May 29, 2015 #3 Re: What year dash? Thinking about it - I'm pretty sure it is Fordor - it was the only body style that kept the gas tank under the seat and I don't think you could fit a speedometer where it is in a car with the cowl tank...
Fredb_ Well-known member May 29, 2015 #4 Re: What year dash? Thanks Mark, would it "fit" in a 26 Coupe?
M mike peterson Member May 30, 2015 #5 yes it will fit a coupe and a tudor also, the speedo hole is to the right of the gas tank that is under the cowl
