Tom Mazz/CT
I feel confident that the starter is in good shape - The engine when hot takes more current than when cold -- I re-read the last post from Vic Piano and he says that he hasn't seen a slow cranking motor ( hot or cold) not fire if the coil was OK.......Today I measured the voltage to the coil (a modern day 6 volt coil mounted on the intake). I had 4.5 volts going to the coil after passing through the under dash ballast resistor. When cranking the hot engine the coil voltage dropped to around 3 volts and I had little or no spark to the plugs.
For now I have by passed the resistor and have the full battery voltage going to the coil. This evening when starting a hot 200 degree engine and although it will barely turn over she will fire right up!
41Ford: The engine history: It was so called "overhauled" in the early 60's installed in the car fired up and driven around the farm for a few laps. The car sat in a barn until 2005. I pulled the engine down and although the cylinder bores had some light rust everything looked good. We cleaned the block up. honed the cylinders re lapped the valve seats - replaced a few that had rusted. Polished the crank - resurfaced the heads and deck areas. The guy that did the machine work checked the piston to bore sizes and I reassembled it. I don't know what the piston / bore clearance was.
I am running 30 weight oil.
Maybe I'll lighten up on the oil and put some miles on it as you suggested.
Thanks all.
Tom
Thanks all.
Tom
