Will a BB Bell work with a T5?
brett4christ
Wondering if a BB bellhousing would work adapting a T5 to a B block the same way an AA bellhousing works with an A block? I know you would have to use the B oil pan as well...
Or would it be better to adapt an A flywheel housing to the B block and use the AA bellhousing?
The pedal adapter should come with the bell housing to trans adapter since you would need it with the AA or BB bell housing.
Bob
If going into an A, it will work but needs rear engine mounts, pedal mount, wishbone mount, etc. If going into a B, just needs rear trans/engine mount.
