cannondalerob
So, will a 35 rear drum work on 39 backing plate with juice brakes and 16" steel wheels?
They will work, but you need to grind off the 5 projections that are there to support the wire wheels properly. It's kind of a pitty though since that's a one year only drum that is sometimes difficult for '35 owners to find if they are still running wires. '40 to '48 drums would work for you with no modifications.
Are the 35 wheel bearings compatible with later rears? I thought there was a thread here about a bearing size change during 36?
Thanks for the responses. I did not win the auction! So I will keep looking. Now I know!
Or this might be the one. He said it went over the lugs.
