I am 99% sure that the 26/27 T visor and the 28/29 CC Pickup visor are the same animal. Both were basically a frame covered with the same material as the top.
I haven't removed a visor from a T, but my 29 CC Pickup has wood screws attaching the top rear of the visor along the underside of the front wood header.
I just re-read the original question and am now thinking that you may want to use the visor from a coupe or sedan on your 29 CC Pickup. If that is what you are wanting to do then the answer is no, not without drilling some new holes in your door pillar. I welded up the holes in my pillar from someone doing just that.
