Wide 5 wheel question
  • Thread starter Thread starter oj
  • Start date Start date
oj
I was wondering if all wide 5's are the same? I've seen them for the Zephyr and wonder if they were different.
Do all wide 5 hubcaps, centers & trims interchange?
For Ford vehicles there are two different sizes:
one size for V-8 85hp and a smaller size for V-8 60hp.
There are two different sizes:
one size for V-8 85hp and one smaller size for V-8 60hp.
That is the width of the wheel, the hucaps are all interchangeable though.
Speaking of width, V8-60 was 16x3-1/2", 85hp Ford and LZ used 16x4", and 3/4 ton pickups used either 16x5" or 16x5-1/2"
The 3/4 ton wheels are not scalloped, so the accessory "spider" caps will not fit those wheels.
Neal
According to page 8-3 of the EFV-8 C/A 1937 Ford Book:
"The 60 horsepower model came equipped with 5.50 x 16 tires on 3.5 inch rims as standard equipment whereas the 85 horsepower model had 6.00 x 16 tires on 4.0 inch rims as standard equipment."
Both wheel types use the same hubcap.
I might be wrong on the width.
2.625" X 18". I'd probably have to look in the book to be sure.
One thing I have always wondered about is that why did some rims have the center section spot welded to the outer rim and some have the center section riveted to the outer rim. Was this different suppliers or was it tied to years or something else?
Charlie Stephens
Charlie Stephens
Good question, I just looked thru my pile and to my surprise one of them was welded, I had thought all were riveted.
maybe they were developing welding techniques ramping up in case of going to war.
I would suspect that welding of the wheel centers in lieu of rivets was an economy measure that Ford or one of their wheel suppliers was toying with.
