Wico JEM Magneto
Not sure what 'tips' you are looking for, but I tried a Wico once and I picked-up horsepower when I took it off. :D The issue I had with mine was it was made for a stationary engine that basically ran at a constant speed, and so the timing is set for that. I didn't feel like I had any bottom-end power. Outside of that, just run a tighter spark plug gap and you are set. You will need a separate ignition switch that will ground the unit when you are ready to shut the engine off.
