Safewiz
Anyone following my post know I purchased my A end of last year and made it my daily driver. The car had been restored in the late 80s by a well known restorer. It had sat for many yrs before I got it and only had 252 miles on it. The only thing as enjoyable as driving this car is maintaining it. That being said, since I do put a lot of miles on it, 120 to 150 miles a week, I run through the service every month. Having put enough miles on it to feel like it was time to check grease in the yolk, after finishing the rest of the grease job. I know I should have done this by now but thought since a well known restorer had built this, it should be good for at least 5000 miles. I grabbed my channel locks for the speedo cable removal and my large grease gun and crawled under prepared to pump my arm off. Surprise, no grease fitting. Did not even see a place for one. I know were it was suppose to be, just was not there. After running my finger around the area it was suppose to be I found a soft spot. I knew I had a problem. Got my drain pan placed under an took a ice pick, no tool box should be without, and pulled out a chunk of silicone. As expected out came a small amount of trans oil. Letting it drain, I wiped the spot, and was relieved to see the threads. Having a set of grease fitting on hand, installed one. My question is why would a reputable restorer do that. And how many other things will I find. I guess they hadn"t done very many Model A fords.
