Cool Hand Lurker
The question of why Henry Ford used positive ground for so many years comes up occasionally on Fordbarn. Some have said it is because it keeps the battery cables from corroding. I just read an article from the Digikey Co online library that stated the same thing so I think I will go along with that theory.
I have included info and a link to the article for those of you who understand this stuff better than I do.
PWM Controller Handles Multiple Topologies with Negative Input Voltages
By Ashok Bindra
Contributed By Electronic Products
2015-07-07
Traditionally, telecom and datacom equipment deliver negative DC output voltage, such as -48 V, for the system bus. The reason is simple: the DC voltage keeps noise low and can be easily generated from regular lead-acid batteries, normally around 12 volts. In addition, the negative supply keeps cables and copper wires away from corrosion. ….............
http://www.digikey.com/en/articles/...tiple-topologies-with-negative-input-voltages
By Ashok Bindra
2015-07-07
