Why oil in radiator model A engine
Lafe
This is a old 9N Ford tractor the engine is like a 4 cylinder Model A. Oil in radiator. NO water in the pan. Lots of oil floating on top of the coolant in the radiator. Head gasket looks great. I am going to check both head & block surface for warping. But oil in the coolant is rare. This engine runs great. Oil pressure is great too.
If oil pressure is pushing oil into the water jacket of the engine block, where is the most likely place to look?
Thanks Mike R
I suggest you ask your question at;
http://www.smokstak.com/
While there maybe some similarities between a Model A engine and a 9N there may be some differences that could be causing this problem. In ether case, this is not the section to ask the question.
