I have read quite a few posts on here with questions about picking and removing Ford lock cylinders. I will not go into detail on how to pick locks here but I wanted to give a little insight into why the HURD locks are so secure. HURD locks are what is known as a pin tumbler lock. There are five pin chambers in each lock and there are two pins in each chamber, plus a spring. The key raises each pin set to a pre-determined height and when this happens the cylinder will turn. When the HURD locks were first introduced on automobiles the pins were all smooth, this made it possible for a person who knew exactly how the locks worked to pick and open the locks. A very simple but effective solution to this problem was to modify the pins to prevent picking. Four different styles of pins were introduced, spool pins, grooved pins, ringed pins, and mushroom pins. If you will notice in the picture each one has it's own configuration. When a person tried to pick a lock with one or more of these pins in the pin chambers the pin could be pushed up to the indentation and the lock cylinder would then turn a small amount. When this happened the pin could not be pushed up any further and the lock cylinder could not turn any further, thus foiling the picking attempt. I will not say that the HURD locks absolutely can not be picked but I can tell you that I have been working on these locks since 1977 and I can count on two hands the number of HURD lock cylinders I have actually been able to pick. Once in a while everyone gets lucky. 32phil has verified this many times in his posts on the board.
I have seen posts on here where some of the guys have dismantled the lock cylinders and made keys for them and this is a viable solution if you don't have a problem working with 15 very small pins and springs plus getting the pin chambers sealed back up so they don't pop back off at the most inopportune time. Luckily most of the HURD lock cylinders have the code numbers stamped on them and that makes it easy to get keys made.
I have seen a few posts that state "just take it to a locksmith and they can pick it". When I see that statement I have to chuckle.... Not only will 98% of the locksmiths today not be able to do that, half of the other 2% won't even want to mess with it because of the time involved.
Sorry about the long winded post but I hope it will give you guys & gals a little insight into why these locks are so secure, and can be a little tough to work on.
LockDoc
LockDoc
