There is no pressure regulator on a model A pump, as it is not intended to create pressure, but volume. The pressure you see is from the friction of the cold thick oil against the passage up the pump body and into the valve chamber, where it dumps out. As the oil heats up, it gets thinner and so can flow easier, and so the lower (or no) pressure reading. An oil guage on a model A only proves the pump is still running, nothing more. The oiling system on a model A is gravity feed to the main bearings and cam bearings, and splash to the rod bearings and pistons. There is no pressure designed into the system.
