In the summer of '71 I helped a man plank a 52' wooden schooner he built in his backyard. The planking was fastened with 'trunnels', this word being derived from tree-nail. This was traditional for fishing schooners as the cod was filleted and pack in rock salt in the hold and this was not a good environment for metal. The 1" locust trunnel was driven into a hole through the planking and clear through the frame behind it. Then the trunnel was sawn short at each end and split with a chisel. The split was vertical on the outside of the hull and horizontal inside at the frame, thus not splitting the plank. If there was something in the way inside the hull such as a bulkhead and there was no access to split and wedge the trunnel, a blind trunnel was used. The hole went only partially into the frame, say 3/4 of the way. A saw kerf was cut into the leading end of the trunnel and a wedge was started into the kerf. As 51 merc stated, the wedge would bottom out on the blind hole and expand. The outer process at the plank side would remain the same. My pilot bearing/bushing puller works on the same principal as the wedge bottoms out on the blind hole in the crank. A lot less messy than grease, although I think that hydraulic method is clever.
