rossofozini
A good friend has a very annoying intermittent problem that's just appeared on an otherwise very reliable car restored in the early 70's.
Every now and then the car will not fire up, it cranks over but seems to loose spark. Problem is the problem is never there enough to diagnose the problem properly. The system has been converted to - earth and is now 12v. The contact system has been modified with a condenser mounted on the upper plate within the distributor, this all looked to be well done and in good order. After poking around the complex
electrical system on the vehicle I suspect one of two possible things may be the cause. First: it has an original ignition switch that seems to work without any issue. What's the reliability of the original switches? Second: In order to keep the car looking original a 12 volt coil was transplanted into an old coil body, however the oil leaked out some time ago. I would personally place my bets on this, owing to the intermittent nature of the problem and knowing there is no cooling oil in the coil. I suspect a fracture in the coil coils.
I have also given the owner some simple test procedures to eliminate other possibility.
Any thought would be greatly appreciated
Ross
Ross
