Brobrian
A few years back I replaced the internals (Sector shaft, worm gear, bushings) on my '28 coupe's steering box in hopes that I could fix the wobble and ease the hard steering. Since then I've also replaced the pitman arm and all the internals on the tie rod ends. Still wobbles and still steers hard. When I first did the steering box, i found that the Lower assembly was shot and the actually steering shaft was all boogered up as well. Couldn't get a machine shop to turn down the shaft so I could fit it in a bigger bushing, so now I'm thinking I'm just to dumb for the job. Perhaps I should send it to a pro. I believe the car has an early AR shaft. If possible, I'd like to keep it original rather than going with the F100 steering box.
Any recommendations?
