Never thought of H&H, I couldn't find anything at Arias or Ross on their web site. ThanksI'd try Arias or Ross, they both make high quality forged pistons for flatheads and can certainly custom make anything you want.
I'd also give H&H Flatheads a call, they manufacture the Navarro parts and he was big into the hi-dome heads for pop-ups. They may sell you the pistons or tell you who they get them from.
I have built quite a few of those 8N-9N tractor engines and have seen a few of those pop up pistions. I was always going to check them out on a flathead but never go around to to it. I don't think that pop up will work with a flathead head. WaltI have seen a set of four in a 9N 4cyl engine. Half the top was pop up and the other half was flat. Never have been able to determine what they were, as they definately would be the thing to pep up a 2/9/8N engine.
There is plenty of meat on the bottom, I wonder if I could mill them down to an acceptable height.Probably someone just machined your heads to use ford pistons with a merc crank. Was done a lot and you need to do a little measuring to see what you got. A shame to not be able to use some nice after-market heads. As Ol'Ron said they worked pretty well when set up right.
