rotorwrench
The old condenser testers checked for capacity test, resistance test, and leakage or insulation test. If it passed all that then it was good to go. The old capacitor testers are hard to find now days.
Not if it's got chewing gum stuck all over it.Kind of OT but when I went to Cali in 81 I threw a set of points and condenser in my glove compartment that I bought from Ford. Is the condenser any good?
Continued... I found this points cam lube in an old box of leftover 'garage' things on a back shelf,Back-in-the-day, new points used to come with a small packet of special grease in the box ...
I need to round up some.
Good to know about condenser. Went to "auto Parts" store a few years back and asked for cam lube, the "person" brought out a small tube of dist cam lube. I said no it's for a camshaft so he went back in the back again and brought out a whole hand full of the little tubes. I left.Not if it's got chewing gum stuck all over it.Otherwise it should be fine.
just in time to fire up my '55. I hadn't seen it since the 70's, moved three times since then.
I believe all new condensers are made in China nowadays, and are crap.
I put a reman distributor in a 64 Falcon and shortly after the customer said it was bucking, stalling and not starting. After checking it several times and it not acting up, it finally went haywire. I traced it to the condenser and put a Standard in, that was several years ago.
Also had an intermittent hot no start on a 73 Impala I had tuned up. Ended up going with HEI and attributed it to the Standard condenser.
