white wall tire cleaning
broommaker
What's the best cleaner to clean the WW tires? Years ago I used a small brass brush, back in the 50's and 60's, I don't remember the cleaner we used.
Thanks, Jim
I use Wesleys bleach white on my perpetually brown-white walls.
Really strong stuff that will screw up your paint if you are careless with splashing.
Superclean is the best product I've found. No abrasives needed! They don't get "brown" and stay whiter, longer. Ron W
Westleys Bleach White, as its name implys contains bleach. I recently contacted the tire manufactures about the brown bleed through problem on the white sidewalls. They all recommended not to use bleach or any product containing bleach on rubber. I now use Simple Green and a lot of elbow greese.
I've tried everything and nothing works like Harley Davidson white wall cleaner. It will make them snow white with very little effort. Dad's white walls had turn brown and it made them snow white. Try it and you will be shocked at the results!
